Nieuwe mods
Gestart door Tdo, 29 september 2017, 16:11:30
Emt 938.   Luxman l507s.  Luxman t-550v.   Cabasse Prao.  Kef ls50.  Harman Kardon 6550.  Composed dv1 dt.  Garrard hf4-mono.    Philips 6415 en 9014 buizenversterker.  dht Rob buizen phono-dude. Harmonizers Sonore. Open baffle Philips 9710 m8.
Zo ziet het er uit, dus even wennen.
Je zat bijna goed, groeffie. ;D
Daar moet toch ergens een "eject" in zitten om jezelf als mod ook te kunnen bannen. Kweetooknietwaar, maar ik zou gewoon alle rode knopjes proberen, komt 't vast goed.
Zelfbenoemd specialist
theo technics
1 oktober 2017, 18:43:22 #48 Laatste wijziging: 1 oktober 2017, 18:49:49 door theo technics
CHECKLIST: Before MOD started:
PRELIMINARY
BEFORE TAXI
RUNWAY ITEMS
AFTER LANDING
Preflight inspection
completed
Avionics Power Switch
on
Landing Light
on
Flaps
up
Papers
on board
GNS 430
on
Pitot heat
as required
All unneccesary switches
off
Torch
checked
Navigation lights
on
Transponder
alt
Time
checked
Seats
adjusted
Flight instruments
checked
Runway heading
checked
Belts
fastened
Radios/avionics
set
Engine performance
checked
AFTER PARKING
Parking brake
set
Transponder
set
Parking Brake
set
Doors
closed/locked
Ammeter/volt meter
checked
AFTER TAKE OFF
Thrust lever
idle
Controls
checked
Alternator warning light
off
Power
checked
Time
checked
Trim
checked
Fuel pump
off
Flaps
up
GNS 430
off
Alt.static air
checked
Flaps
checked
Trim
set
Avionics power switch
off
Electrical equipment
off
Briefing
completed
Landing light
off
Main bus switch
off
Circuit Breakers
in
Altimeter
set
Engine master
off
Batt/Alt/Main bus
on
WARM UP
Battery switch
off
on
890 RPM
2 minutes
CRUISE
Beacon light
off
ATIS & Start up
received
1400 RPM
OT 50°C CT 60°C
Cruise power
set
Control lock
install
off
Fuel pump
off
Fuel Selector Valve
L or R
TAXI
Temperatures
checked
BEFORE STARTING
Time
checked
Trim
set
PRE STALL CHECKLIST
Fuel quantity & temp.
checked
Brakes
checked
Directional gyro
checked
No loose articles
checked
Fuel selector valve
both
Gyros
checked
Belts
fastened
Fuel shut off valve
open
DESCENT
Instruments
checked
Alt. Air door
closed
BEFORE TAKE OFF
Fuel selector
both
Fuel pump
on
Thrust lever freedom
checked
Parking brake
set
Power
set
Fuel quantity
checked
Cabin doors
locked
Altimeter
set
Altitude
checked
Window
closed
Position
checked
Beacon light
on
Flight controls
free and correct
APPROACH
Orientation
checked
Fuel pump
on
Flight instruments
set and checked
ATIS
received
Sky Clear
checked
Thrust lever
idle
Fuel quantity
checked
Altimeter
set
Engine master
on
Fuel selector valve
both
Avionics
set
AFTER STALL CHECKLIST
Load display
0
Trim
set
Approach briefing
completed
Power
checked
Glow light
off
Thrust lever
idle
Seats
upright
Flaps
up
Prop area
clear
FADEC test button
press and hold
Belts
fastened
Fuel pump
off
Starter
on
Thrust lever
full forward
Brakes
checked
Directional Gyro
checked
Oil pressure
checked
(min.94%)
Instruments
checked
CED Test knob
press
Thrust lever
idle
Fuel selector
both
Ammeter/Volt meter
checked
Engine Instr & Amm.
checked
Fuel pump
on
Suction
checked
Flaps
set
Flaps
set
FADEC BACK UP BATTERY TEST
Fuel pump
on
LANDING
Alternator
off
Clearance
received
Landing light
on
Battery
off
Radios and Avionics
checked
Flaps
set
Battery
on
Briefing
completed
Alternator
on
Thrust lever friction control
set
CED Test knob
press
Brakes
release
Time
checked
Knoppen lampjes meters schakelaars ik vind het jammer dat ik niet voor mot geschikt ben ;D
Gewoon op het licht af gaan, groeffie. ;D
Citaat van: Opa Spylac op  1 oktober 2017, 18:43:12
Dan heb je het zeker over een definitieve ban? Want bij "eject" zien we de mod in kwestie natuurlijk nooit meer terug.
AVM CD1+/G. Tent Clock, Yamaha CDR-HD1000
Linn Sondek LP12+AT ART9, Micro Seiki DD-5E+AT33 PTG/II, Jobo Acoustical 3100+Shure V15/III
Luxman WL550, Nakamichi 680ZX, Akai GX-635D
Classé CP-800 en CA-2100, JK Acoustics Ultimate Phono, Graham Slee Reflex C
Heil AMT Syrinx, Philips FidelioX2
Audioquest
geerd
dacht meer dat het zoiets was met de text geef en ram bij een ban
Citaat van: Jeronimo op  1 oktober 2017, 19:31:38
Roeivogel
Beide heren veel succes gewenst.
Ik weet niet wat er zich allemaal (in het audio-lamp topic) heeft afgespeeld de laatste dagen met deze gevolgen. Wellicht is er ook flink gebezemd.
Ik kan er dus moeilijk een mening over vormen omdat ik de feiten niet ken.
Het is wel jammer vast te stellen dat (voor nu) een aantal audiofreaks heeft besloten hier niet meer te posten. Nou is dat natuurlijk ieders goed recht.
Ik hoop wel dat hier de tendens van alles in hokjes plaatsen en alles verwerpen of veroordelen wat niet in je eigen straatje past (wat ik de laatste tijd op andere sociale(?) media zie gebeuren) zich niet doorzet.
Verder wat Opa Spylac typt.
ADAM ARTist 5 / B&W DM2A + DM4 + DM5 / Dual 721 / Eltax Linear Response 10.5 / Onkyo A-809 / TvW CD104 / Sansui AU-7500 / Sony CDP-XB930 / Sony MDS-JB980 / Technics S(pylac)A-600 / Technics SL-Q3 / Technics SL-7 / Technics SL-10 / Technics SC-EH600 / Thorens TD-320 Mk II
Rood
De meeste bans komen zo tot stand :
De audiolamp zie je links in de hoek stralen  ;D
Znx, roeivogel.
Een deel was voor mij ook een raadsel en sommige dingen blijven mij een raadsel.
Wat ik zag was dat op een klein onderdeel, een honderdste(?), van een forum waar we allemaal (hoop ik) komen omdat we een gezamenlijke hobby hebben, nl. muziek en hoe er van te genieten, een discussie wat uit de hand lijkt te zijn gelopen.
Waar gaat het dan uiteindelijk over?
Een heel klein onderdeeltje van het forum...
Is het zo iets ongelofelijk belangrijks om er enorme ruzie over te maken?
We willen toch gewoon genieten van iets buitengewoon moois, dingen delen en daardoor meer en samen genieten, elkaar adviezen geven en helpen waar mogelijk?
Muziek, audio en alles daar omheen.....
Soms botst dat misschien af en toe even omdat ieder zijn eigen smaak heeft in de vele dingen die met muziek te maken hebben.
Maar dan vind ik het doodzonde dat mensen, die je op een fijne manier hebt leren kennen, soms persoonlijk, soms via pm's, mails, telefoon of alleen al via het uitwisselen van dingen op het forum, afscheid nemen waar ik het gevoel heb dat het absoluut niet nodig is.
En ook is het jammer als mensen de zaak even niet meer kunnen relativeren en een bedenkingstijd moeten krijgen omdat er anders weer anderen voor wie daardoor hetzelfde gaat gelden (ook)  te heftig gaan reageren.
Daarnaast heb je natuurlijk altijd mensen die het leuk vinden om bushokjes te mollen, kikkers op te blazen, anderen het ziekenhuis in te slaan of een forum kapot te maken....
chansig
Citaat van: Rood op  1 oktober 2017, 22:16:43
Gr. Hans
