Denon PMA 960
Gestart door Rood, 8 september 2019, 18:40:27
Rood
Ooit een keer hier besproken : https://forum.audiofreaks.nl/index.php?topic=42401.0
Later aangesloten en er kwam via een CD speler en een paar boxen geluid uit .
Eigenlijk overcompleet maar staat niet in de weg .
Tja de waarde ... voor 100 euro doe ik hem niet weg maar ook weer niet voor 500 euro  maar dat mag wel trouwens ;)
Output power
(both channel drive, a sine wave continuation output)    170W+170W (6ohms)
140W+140W (8ohms)
Input sensitivity/impedance    150mV/47kohm
THD    0.003%
Cross modulation distortion    0.002% or less
TIM distortion    Below measurement full limits
Slew rate    More than �}350v/microsec
Output bandwidth (both channel drive)    5Hz - 80kHz (THD 0.02%)
Frequency response (at the time of 1W output)    1Hz-250kHz+0 -3 dB
Output load impedance (1kHz)    0.1ohm
Output terminal    Speaker AorB: 6ohms - 16ohms
Speaker A+B: 12ohm-16ohm
Headset jack: 550mW/eight ohms
<Preamplifier part>
Input sensitivity/impedance    Phono MM: 2.5mV/47kohm
Phono MC high: 0.25mV/100 ohms
Phono MC low: 0.125mV/100 ohms
DAD, Tuner, Aux, Tape:150mV/47kohm
The maximum except take-off/Output power    14.5V/150mV
THD    0.001% or less (1kHz, 8V)
RIAA deflection    20Hz-100kHz�}0.2dB (MC/MM)
<Synthesis>
Signal to noise ratio (an input short circuit, Weight A)    Phono MM: 90dB (at the time of a 2.5mV input)
Phono MC: 75dB (at the time of a 0.25mV input)
DAC, Tuner, Aux, Tape: 110dB (at the time of a 150mV input)
Tone control    Bass: �}8dB (50Hz, 100Hz)
Treble: �}8dB (10kHz, 20kHz)
Subsonic Filter    18Hz, 6 dB/oct
Muting    -20dB
Loudness control characteristic    Low-pass: +7dB (100Hz)
High region: +6dB (10kHz)
Power source    AC100V, 50Hz/60Hz
Power consumption    245W
Dimensions (a base, a knob, a terminal included)    Width 470x height 168x depth of 440mm
Weight    15kg
Rood
